Public·389 members
Large number of Grid Disconnection Notifications
In the last 7 days (since 22nd Apr) I've been getting a ramp up in Grid Disconnection messages.
Happens when inverter is feeding house via battery or PV and NOT when using Grid input.
The 8kW inverter always restarts within 1 minute, so grid use is very small.
Usually happens at night (28th Apr saw 4 events) but I've had 2 already this morning (29th Apr).
Is there any data on screen/App or via Home Assistant that i should pull up to find any helpful info, or just direct this to SS Tech help?
jacekowski
Apr 29, 2024
The graphs you get from app/website are useless for diagnosing intermittent fault like that, even if you have them updating at 60s.
However, the fact that you are seeing a sudden dip like that, even though you are probably not seeing it fully, shows that there is a problem on the grid side.
