Public·324 members
Using Sunsynk 3.6kWh ecco with Tigo CCA Data logger
I am currently using Sunsynk connect to monitor my installation.
Everything is working fine, but i would like to further utilise the Tigo CCA dataloger that was installed (along with Tigo optimisers) so that i can compare the Tigo and Sunsynks applications.
The Tigo CCA has two RS485 connections, and supports the Modbus protocol for data transfer.
My intention is to connect the inverter using an RS485 Port to one of the Tigo CCA's RS485 connections.
Does my inverter actually have an RS485 port that supports the Modbus protocol that i could use?
I have looked at the installation PDF and users guide but this doesnt state if i do have the required port. It does however give the pinout connections for the RS485 connections ( A and B ).
I believe the only port being used currently is the BMS port for the battery management.
i would be interested if anybody else has tried this setup and how succesfull they have been.
Chris
