Public·324 members
G100 support
I have an existing solar install which I don't want to touch in anyway. I'd like to add an ECCO inverter to top up the export to 5Kw when the existing array get shaded, but not discharge the battery. Can this be setup ?
jacekowski
Apr 18, 2025
Yes, you can set maximum power at PoC which sunsynk will try to follow by limiting export, but that alone will not mean your installation is G100 compliant (and chances are DNO will want a witness test when you achieve compliance with external G100 relay), it will be better to get a larger inverter (for efficiency reasons as well)
