How much power does an inverter use?
I have a really basic system, no battery and the Sunsynk 3.6kWh inverter.
My bill tells me I use around 100 units overnight. How much of this will the inverter be using when idle? I was considering powering down the inverter overnight for a month to find out, but if someone knows for sure how much (if anything) this inverter uses at idle, it wil save me from doing that.
Thanks
Sorry Steve - I mis-read the no battery. LPM doesn't apply without a battery.
Overnight - the inverter will be powered by grid - 50-100W.
Your load of 300W is consistent with ours - fridge freezer, router, inverter, tv & the occasional device charging.
