Time setting on inverter part 2
Earlier i asked help as my inverter time settings go hay wire when the server is off.
I have reset the time and did not activate the sync button.
Reasoning.
If i activate the sync button the it will sync it with the app. If not then it will use the time that i set on the inverter.
The server is now off and an hour later my time setting is still correct.
Hopefully i have solved my problem
I am in South Africa too so trust me I understand the loadshedding thing very well🤢
