Public·382 members
UPS mode with Solar export to Grid
Going to install a 5kw Sunsynk from a grid tie inverters. I currently export to grid. So the PV strings will move over to the Sunsynk.
My question is I want to maintain battery charge and only discharge when I loss the grid (eg load shedding). My PV, must export to Non essentials and grid when the sun is out.
Settings: Will battery charge set to grid and Work mode set to Zero export and Solar export with max PV wattage be the solution for my setup without using the timer function.
Thank you in advanced
