Public·472 members
Can sunsynk inverters have a g98 mode?
Do 5kw or 8kw inverter have a g98 mode, where the export be limited to 3.6kw.
So that it can be installed and not need the full G99 process?
Or can they have it added please?
AVONSIDE
Mar 28, 2023
It will be export limited under G99 not G98.
So G99 application that is given a G100 export limitation. GRID setting on the Inverter will be G99 with the export limit set to the G100 approval limit.
