Public·472 members
Explanation of energy flows
Hi
We have an 11kw system with 2 inverters and 2 batteries
Looking at the flow diagrams for each I cannot understand the differant loads taken form the grid for each, attached are the images for each
Cheers
shaun
Jul 03, 2023
Thanks so much for the reply, I think you have clarified the initla point I assumed the house consumption was read y the sensor so would be the same for both inverters, from what you mention each inverter handles its delivery and consumption in its own right so that now makes sense on the figures.
We have a master / slave setup I beleive in Parallel, the batteris each hang off their own inverter. The gut that did the final wiring was fine for that but I dont think he fully understood the SunSynk setup, the support team helped remotely configure it but I am still not sure its 100% I may have to see if I can find a remote engineer who can check all the config is ok
