Public·384 members
Always a small trickle export
It seems when the battery supplies the load, the generation drops off or it’s nighttime I get a very small trickle export to the grid. Sunsynk doesn’t register this as it uses the CT coil but my smart meter shows it. This I assume is because the smart meter is newer and gets it’s information directly from the meter
The reason I ask is this small trickle export confuses my water heater on occasions
Picture here showing -4w trickle export as house is being supplied via a full battery.
Can I stop this ? Or I assume it’s just a symptom of how inverters work
Ben Leitch
Jun 26, 2024
I will try this - thanks
