Public·371 members
Connecting DC Input to MPPTs
Hello everyone, i was just wandering about this paragraph “connecting a DC input to mppts.
Does this mean you can for some reason connect a DC power supply to your mppt input, and if so what will the limitations be, say you have a dc power supply that gives you 30kw at the plus minus 800V, and you have a 50kw inverter, you have 4 inputs Of which 3 is connected to panels can you connect the power supply to the remaining mppt input.
globetrotter
19 jun 2024
Are we sure the DC input connector is fully isolated from the grid connections / voltages? I have seen mention on here that being a transformerless design the MPPT inputs are not isolated. Scary!
