14KW Solar ? Should I Parallel
If someone could assist, I have 1 Sunynk (8kw) connected to an array of 7kw of solar panel's. I have an additional 7kw array that I would like to connect to bring my total peak power production to 14kw, if I add a second Sunynk (8kw), will the combined solar output be 14kw ?
You can only connect 10600 W on a 8kw inverter if you want to ad more you have to ad another inverter
