Battery drain
My Pylontech batts charge to 100 % SOC. A-C coupled grid feed only, Why when the sun goes down why do my batteries drain at the rate of about 1% per hour???
If I charge the batts and disconnect them from the inverter they stay at 100%. What is causing this drain??? Is there a setting to stop this. Pylon techs can be discharged down to 5%, but with this drain 5% is not achievable as it goes past this point.
The batts charge and discharge normally from the timer.
All those intrested should read about the new tarriffs that may come in for the time period 4PM to 7pm.
There may be rebates available?
The inverter idle consumption causes the drain
