Public·519 members
Feature request, better charge controls for unsupported LIFEPO4
We need better battery charging section for unsupported BMS's We also need a list of supported BMS's rather than just pre built battery support.
Building your own battery is a simple process and saves A LOT of money, so it would help if you told us what BMS is best with your inverters.
However for those that want to use an unsupported BMS we need Bulk, Absortion V (the same so just one would do it) absortion time. Float voltage, Tail current and the offset v offset for restart of the charge process.
Just copy Victron, they seem to have it nailed.
MOD
MOD
06 sep 2023
Thank you for your feedback, will share this with the team! For now your best bet is to communicate with customerservices@sunsynk.com.
