Public·332 members
Earth Neutral bond wording in documentation ambiguous
While investigating the whole earth/neutral bond relay topic this sentence pops up in all the Sunsynk documentation, and even in a few posts from @Keith Gough and the wording is confusing and I suppose it's just a typo?
"If an Earth Bond is required between neutral and earth and your system is a hybrid system then you can have a permanent earth wire since this can cause faults with an RCD before the inverter"
Should it not be: "If an Earth Bond is required between neutral and earth and your system is a hybrid system then you can't have a permanent earth wire since this can cause faults with an RCD before the inverter"
Or am I missing something?
Leon Botha
Jan 28, 2023
Hi Keith I don't use an Earth Bond Relay, I have "Grid" Earth and "Inverter" Earth on the same point permanently connected.
