Public·399 members
Sunsynk 8.8KW Inverter + 5.32KW Battery Settings
Hi,
What are the optimal battery settings for a combined SunSynk 8.8KWh Inverter and 2 x 5.32KWh batteries?
Specifically, what should the following be set to:
- Batt Capacity, since they are 104Ah battery, should it be set to 208Ah.
- Discharge Amps, what should it be set to, the maximum charge/discharge rate per battery specification is 100A, should this be set to 200A, i.e. 100A x 2, or adjusted to a lower value as set in image below
- Charge Amps, what should it be set to, the maximum charge/discharge rate per battery specification is 100A, should this be set to 200A, i.e. 100A x 2, or adjusted to a lower value as set in image below
- Under Grid Charge, what should Grid Start and Grid Amps be set to, at the moment set to 30A and 40A respectively, specifically for the two batteries, should it be set to 40A x 2, ie. 80A for both batteries?
Regards,
Ahmed
Ahmed Omarjee
Ahmed Omarjee
May 02, 2023
Thank you so much for the feedback, much appreciated, will go ahead and make the changes accordingly.
