Public·392 members
Solar advice
Hi. Want some advice on fuses. Is it a must or law to add additional fuses between battery and inverter Wil add photo aswell
On the gel battery's I could understand but most batteries have a bms communication and a on and off switch. In case something might happen won't the bms shut down the battery and go into alarm. To disconnect the battery you can switch of battery and inverter Wil go into alarm and also switch off. So my understanding is that the fuses is basically not a must. I don't know if there is a law that says it's a must that why I'm asking
