Public·395 members
How to setup "Absorption Time" in Sunsynk Inverter
I have 2 5kW Lithium batteries which i need to charge to 100% at 55.6V, carry out absorption at 55.6V for 30min the current drops to 2A for both batteries and then switch to float voltage of 53.6V until the battery is used.
I have looked through the 5kW inverter and i cannot seem to find the absorption time, how do i setup my battery for charging as above?
jacekowski
Apr 10, 2024
BMS should command whatever voltage and current it needs and inverter will deliver requested voltages/currents.
