Sunsynk PV Power
Good morning,
I have the following system installed
- 5.5kVA Sunsynk Inverter
- 12 x 450W JA solar panels, two strings of 6
- Hubble 5.5kWh battery
- Solar panels installed on roof facing north without any obstructions
The readings in the photo is a test I conducted to confirm the power being generated by the PV. The load was 3.79kW, the PV produced 2.71kW and the remaining 1.1kW was drawn from the grid (Taken at peak solar production time 12:00).
My question is for the max theoretical solar power delivery of 5400W is the current value of 2.7kW acceptable?
I have been performing a couple of tests and the max PV power delivery I could achieve was 3.4kW
But I have no idea if this is good or bad, some guidance will be greatly appreciated.
How have got priority load or battery selected? Could really do to see the screen that shows what each array is producing so you can see if perhaps you have an issue with a string?
