why is Load always higher than battery output?
I'm running exclusively from battery currently and my load is consistently higher than the battery.
usually 100-150 but sometimes by as much as 300w!
does anyone know of this is a misconfiguration or typical for a battery system?
it doesn't seem right for it to be higher at all times.
some screenshots as its occuring
spoke to the installers and they say it is a CT Coil issue and will send someone out to double check the installation. im unserstnad you on losses etc but i dont understand how the home load can draw more than the battery is outputting. if it was the battery outputting more and the load recieving less id unserstand it as losses
