Public·324 members
Discharge and Timers
Quick question,
When the timers are turned off in 'System Mode' should the batteries not still discharge to the setting within 'Battery Settings'?
I have a customer who charges from the grid overnight on random occasions (he decides if he want's an overnight charge and switches on/off accordingly)... however turning the timer off (when not required) prevents the system from discharging the following day (unless switched back on).
Can anyone advise on this? I'm not sure if this is a fault or just a flaw.
Many thanks
Renewafuel
Sep 25, 2023
Thanks for the feedback,
The hope was that he could discharge his system with the timer being switched off. Suppose he'll need to do what he's doing (pretty much your suggestions) and keep changing the timer settings.
Thank you 😀
