Uk low power mode
Hi i have my inverter set to low power mode and the inverter switches off perfectly when the battery reaches the low soc i have put in the settings, its the start up im a bit confused about i believed it was ment to start up when pv power was starting up but for some strange reason it starts up at 6.10 in the morning about a hour before any pv power is available does anyone else have this issue.
I think your right its picking up a bit or solar the the app isnt showing it as its not always right hust gives a idea whats happening as this morning its brighter and switched on earlier. And good luck with rcd
