SUNSYNK 10kWh BATTERY SETTINGS
I have connected 3 x 10kWh batteries in parallel. The Comms cable goes from the master battery to the master inverter (I have 2 x 8kW inverters in parallel). The link cables go from master (link out) to second battery (link in) and the (link out) to third battery (link in).
I cannot get the dip switch configuration setup correctly to allow the BMS to communicate with the inverter. If I start with one battery (200AH) all is good, but as soon as I add the others I lose proper comms. Any suggestions?
Thanks Mark. We're still waiting for a lot of the SunSynk products in the UK. Hopefully the 16kW inverter will be released here before the end of the year.
