Battery charging issue
I did post couple days ago enquiring why with 3.47kw being generated from panels and battery soc at 34% I had 1.96kw feeding back to grid with only 0.98kw to battery. Battery temp 7°c. You answered charge current limited to 1 kw when battery temp below 12°c.
Today battery temp at 17.5°c 3.550kw being generated with 2.410kw to grid and still only 1.010kw to battery. Soc 70% do I have a problem here, should I get my installer back to check settings? Or is this normal. My last post gives system details.
Please advise
Thank you.
I am having the same issue did changing this setting help?
