Feature Request
Can we have a max SoC in the timer slots?
When a slot starts, if the battery SoC is above max SoC the inverter switches to Selling First until the Max SoC is reached, at which point it reverts back to its previous setting Zero Export. At that point it could export everything to keep the battery at that level for people would want to preserve space in the battery for later in the day
Can the Power setting in each slot dictate the maximum power for discharge and charge depending on whether you are charging or discharging in that slot.
Also can Solar Export only activate when there is something to export. The inverter can be stopped from drawing 40w from the grid by turning off Export Solar until needed. This could be automated in the software.
agree
