Public·389 members
Exporting while set to Zero Export?
Can someone please assist?
Invertors (2x 5kW Sunsynk), house has old eskom wheel power meter.
So old wheel meter turn only 1 direction, while ""exporting"" without concent Minuspality think I am using power..
Zero Export selected, CT installed, but exporting sometimes 400W, Export limitation is 500W, this is the minimum selection.
Is there a way to stop exporting?
jacekowski
May 14, 2025
That's not the right setting to use. You need to change work mode to zero export.
