Router can't connect to the data logger
After installation I connect the data logger to the Wi-Fi by using the steps as explain in the data logger guide, connect directly to the dongle via Wi-Fi to EAP_*****. Everything went well and I could monitor my plant on the pc. A while back the app couldn't connect to the router anymore and I also see the inverter's system time didn't stay on time, after I removed the Wi-Fi stick the system time stay on time.
After a day I reconnect the Wi-Fi stick and the system time stay correct but still can't connect to the router. I'm using a D-Link model: DSL-750U router and the WI-FI stick model: EESW-D205.
What could be the problem?
If you out in the ip address of the stick, can you bring up the config screen first? If not can you see the EAP name on your network? Also try restarting the router.
