5kw Sunsynk inverter with matching solar panels
The 5kw sunsynk inverter has a maximum 11amps per MPPT. Can I use the larger 550watt solar panels with a short circuit amp rating of 14 amps without risking damage to the inverter or do I need to go with a 8kw inverter & pair with larger panels
Thank you so much for the detailed response Francois. This really address my concern about potential damage to inverter when pairing incorrect panels.
Look forward to Keith’s response given that the new 5kw inverter spec is 13 amps
