Public·392 members
No display on li bms.
Recently installed lithium battery but can't seem to get any display on the li bms
charging and discharging ok. Have tried both CANand RS485A
Cables ? Any suggestions
AVONSIDE
Jun 11, 2023
you [somehow] have the wrong connections!
It should be PLUG&CONNECT if you have the right connections.
Have a carful look at the Battery connection requirments and the Inverter - not all cables will be the right connections AND some Batteries have different terminal connections at the battery end to the Inverter end!!!
