Public·332 members
Sunsynk Ecco 8kw hybrid voltages
I have a current setup of 24 qcells G9 350w panels split into two strings of 12 panels, running on a non-sunsynk inverter.
The spec of the panels:
I would like to swap out my existing inverter for a Sunsynk 8kwh hybrid but I need to be 100% certain I won't run into any voltage errors with the 12 panels per string (in series)
Sometimes the voltages might spike to 450v when cold but usually sit lower.
I believe that @Keith Gough said in one of his videos that the inverter can realistically handle 520v which I would be way under anyway but I need to be sure if it hits 450v that the inverter won't shut itself down as a protection mechanism.
