HIVE Bridge
Hello, My installer has put in the sunsynk inverter, and trying to attach a Hive Bridge to it, to allow the visibility of the state of play on the Hive app. the hive app is showing the bridge as working but with a red light which means it cannot connect to the invertor, it is plugged in. The installer has completed a change of all cables and even swapped out the invertor, rewired it all up again and still has the same issue. can you help?
