Public·406 members
Forcing the inverter to charge battery from utility
My question is regarding the Sunsynk 5kVa parity inverter.
What is the quickest and easiest way to force the inverter to charge the system battery from utility?
The application is as follows: One knows there is going to be a utility power outage and you want to fully charge your battery bank before this happens.
This system mode screen has the start and stop time options.
Many thanks - Tim
Funtec
Funtec
May 03, 2022
Easy as that! Thanks Vassen.
