Routing cables through heat sink?
A quick question about the suitability of routing cables through the heat sink of an ECCO 5kW. If your electician did this would you request they route it away from potentially hot fins? Or is this all fine?
External bonding is not required. Inverter is bonded internally and then earthed.
