LVTOPSUN Power Wall
I have a Sunsynk 5kw inverter with a 10kw (2x 5kw) LVTOPSUN LVTS-512200 power wall battery pack.
This combo works well in when used in UPS/Backup mode, but when I want to start using it more economically, the battery pack seems to drain over a period of time, although the inverter reports all is okay.
Is there anyone on the forum that has a similar combo and have similar issues?
@Groots - Thank you for your help. Got the installer to fix the battery comms. I have now put the timer back on and will be monitoring it for the next few days to see if the battery holds up.
