Solar and battery storage can come with a lot of kit. Inverter, battery, isolators, connections – and somewhere to put it all. The Sunsynk Lifelynk takes a different approach.
Designed as an all-in-one energy storage solution, Lifelynk brings the hybrid inverter, battery and key components together in one compact unit. The idea is simple: less equipment to install, a cleaner setup and an easier way for customers to start generating, storing and managing their own energy.
Everything in one place
Say goodbye to complicated installations. With our innovative all-in-one system, everything you need is conveniently enclosed in one module. This includes the battery, inverter and all the relevant plug and play connections, saving you time and effort. What’s more, we’ve incorporated essential features such as battery isolators and a built-in UPS with an earth-neutral bond, ensuring both safety and reliability. Less time spent on setup, more time for your customers to enjoy the benefits of solar power.
Your energy, on your screen
Our commitment to simplicity extends beyond installation. The Lifelynk Series is compatible with our Sunsynk Connect app, which offers a user-friendly interface. This means that customers can keep a close watch on the system’s performance, receive real-time alerts, and make necessary adjustments wherever they are. This gives your customers the confidence to enjoy the maximum benefits of their solar power system with ease and peace of mind.
Download Sunsynk Connect to explore. Available on Apple, Google and Android.
S, X or XL?
Homes aren't one-size-fits-all, and neither is Lifelynk.
The Lifelynk S combines a 2.5kW hybrid inverter with a 2kWh battery, making it the smallest member of the range.
Step up to the Lifelynk X and you get a 3.6kW hybrid inverter paired with 3.84kWh of battery storage.
Then there's the Lifelynk XL, combining a 5.5kW hybrid inverter with a 5.22kWh battery for homes with greater energy requirements.
Three sizes, but the same idea behind each: bring solar and battery storage together in a system that's straightforward to install, use and monitor.
And it doesn't have to stop there
If energy requirements change, the system has room to grow too. Up to six Lifelynk units can be connected in parallel, while the system can also work alongside compatible external battery storage. That gives installers more flexibility when designing a system today while keeping future energy requirements in mind.
Whether it's the compact S, the X or the larger XL, Lifelynk is all about taking some of the complexity out of residential energy storage.
Less kit. More flexibility. One all-in-one system.
Explore the Sunsynk Lifelynk Series to find the right model for your next installation, or find your nearest Sunsynk distributor to check availability.
29 September 2026
22 September 2026
22 September 2026
What Is a Hybrid Inverter and How Does It Work?
22 September 2026
