Oversizing with spare panels
Hi. I have an aged 3.6kw solar inverter system feeding into a Sunsynk inverter with x2 5kw Sunsynk batteries but want to oversize my home solar panel with a spare 300w moveable panel from my motorhome.
Is there any way to simply plug this spare panel into the Sunsynk inverter to suplement the batteries on cloudy winter days? The panel is just sat there doing nothing when its potential <0kw could be used indoors....
I may also be adding a small (400w) wind turbine later if connecting additional hardware is easy to do.
Many thanks.
Hi Owen. Would it be as simple as plugging in the two PV solar connectors from the spare 300w solar panel to the underside of the unit as seen in the photo above?
The solar panel has no MPPT & purchased so as to fit into an existing system, either in a house or RV.
If that is the case I could run a perminant cable to an accesable location ready to swap out as & when not in use.
