A solar inverter converts DC electricity from solar panels into usable AC power for your home. Learn how the technology works and why choosing the right inverter matters.
A solar inverter is the core component in any solar energy system. Without it, the electricity generated by your solar panels cannot power a single appliance in your home. Understanding how a solar inverter works helps you make better decisions about system design, product selection, and long-term energy savings.
The global solar inverter market was valued at over USD 10 billion in 2023 and continues to grow as more homeowners and businesses adopt renewable energy systems. In the UK alone, over one million solar battery storage systems are expected to be installed by 2030, according to the Energy Saving Trust. The inverter sits at the heart of every one of them.
This article explains what a solar inverter does, the different types available, and why the right choice matters for your system.
What Is a Solar Inverter?
A solar inverter is an electronic device that converts direct current (DC) electricity, produced by solar panels, into alternating current (AC) electricity, which is the standard form used by household appliances and the national grid.
Solar panels generate DC power because they produce a consistent, unidirectional flow of electrons. Your home's wiring, lighting, and appliances run on AC power, which reverses direction many times per second. The inverter bridges that gap.
Beyond basic conversion, a modern solar inverter also performs several other roles, including monitoring system performance, protecting the grid from back-feed issues, and in the case of hybrid inverters, managing battery storage and grid interaction.
Key Fact
All UK grid-connected solar inverters must comply with G98 or G99 engineering recommendations, which govern how distributed generation equipment connects to the electricity network.
Source: Energy Networks Association, G98/G99 Requirements, 2019.
How Does a Solar Inverter Convert DC to AC Power?
The conversion process happens in several stages inside the inverter unit.
Stage 1: Maximum Power Point Tracking (MPPT)
Before conversion begins, the inverter's MPPT circuit monitors the output from the solar panels and continuously adjusts the electrical load to extract the maximum available power. Solar panel output varies with sunlight intensity, temperature, and shading, so MPPT is essential for efficiency. Most quality inverters, including the Sunsynk Lynks and LP ranges, use dual or multi-channel MPPT to handle panels on different roof orientations.
Stage 2: DC-to-AC Inversion
The inverter uses power electronics, typically insulated gate bipolar transistors (IGBTs) or MOSFETs, to switch the DC current on and off at high frequency. This creates a stepped or modulated waveform that is then filtered and smoothed into a clean sine wave matching the grid frequency of 50Hz in the UK. The quality of this output waveform directly affects how well sensitive electronics perform.
Stage 3: Grid Synchronisation and Export
Once the AC output is produced, the inverter synchronises with the grid supply in terms of voltage, frequency, and phase. Only then does it allow power to flow. This synchronisation protects both your home's electrical system and the wider grid. If grid power fails or drops outside acceptable parameters, the inverter disconnects automatically, a requirement under G98/G99 to protect engineers working on the network.
Evidence
Multi-string MPPT architecture can recover up to 25% more energy from partially shaded or
mixed-orientation arrays compared to single-MPPT designs.
Source: IET Renewable Power Generation, 2021
What Are the Different Types of Solar Inverter?
Several types of solar inverter are available for residential and commercial installations. The right choice depends on your system size, roof layout, and whether you plan to add battery storage.
String inverters: The most common type for residential systems. Multiple panels are wired together in series strings and connect to a single inverter. Cost-effective and straightforward to maintain, but output can be reduced if one panel underperforms due to shading.
Microinverters: Fitted directly to each individual panel, converting DC to AC at the source. Ideal for complex rooftlines with partial shading, though installation costs are higher.
Hybrid inverters: Combine solar inversion with battery management in a single unit, making them the standard choice for systems with energy storage. Sunsynk's full range of hybrid inverters is designed for this use case.
String inverters with DC optimisers: A mid-point solution that adds panel-level power optimisation to a standard string setup, improving yield without the full cost of microinverters.
High-voltage inverters: Designed for larger residential or light commercial applications where higher battery voltages deliver greater efficiency over longer cable runs.
For most UK homeowners adding or upgrading a solar and battery system, a hybrid inverter is the most practical and future-proof option. You can explore Sunsynk's full inverter range at sunsynk.org/products/inverters.
What Does a Hybrid Solar Inverter Do Differently?
A hybrid solar inverter goes beyond simple DC-to-AC conversion. It manages energy flows between four sources simultaneously: solar panels, battery storage, the grid, and your home's loads.
Here is what that management looks like in practice. During daylight hours, surplus solar energy that cannot be used immediately is directed to the battery rather than exported to the grid at low feed-in tariff rates. In the evening or on cloudy days, the battery discharges to supply the home, reducing reliance on grid electricity at peak prices. If the battery is depleted or demand is very high, the inverter seamlessly draws from the grid.
Advanced hybrid inverters, such as Sunsynk's Lynks series, also support time-of-use tariff optimisation, allowing the system to charge batteries from the grid overnight when electricity rates are at their lowest, then discharge during expensive peak periods. This functionality alone can significantly reduce energy bills for households on variable tariffs such as Octopus Agile or Economy 7.
Sunsynk hybrid inverters are also compatible with the Sunsynk Connect app, which provides real-time monitoring of all energy flows and remote system control. For a complete energy storage solution combining inverter and battery in a single enclosure, visit sunsynk.org/products/all-in-one.
Frequently Asked Questions
What does a solar inverter actually do?
A solar inverter converts DC electricity from solar panels into AC electricity that your home's appliances and the grid can use. It also handles grid synchronisation, safety disconnection, and in hybrid models, manages battery charging and discharging to maximise self-consumption.
How long does a solar inverter last?
Most quality solar inverters carry a manufacturer warranty of 5 to 10 years and have a typical operational lifespan of 10 to 15 years. Lifespan depends on operating temperature, installation quality, and product build. Sunsynk inverters are designed and tested for long-term UK residential use.
What is the difference between a hybrid inverter and a standard inverter?
A standard string inverter only converts solar DC power to AC. A hybrid inverter does this and also manages a battery storage system, coordinating energy flows between solar, battery, grid, and home loads. Hybrid inverters are the preferred choice for any installation that includes or plans to add a battery.
Do I need a new inverter if I add a battery to an existing solar system?
If your existing solar system uses a standard string inverter, you will typically need to either replace it with a hybrid inverter or add a separate AC-coupled battery inverter. A Sunsynk hybrid inverter handles both solar and battery management in a single unit, simplifying the installation and reducing equipment costs.
Can a solar inverter work without battery storage?
Yes. A solar inverter can operate without a battery and simply convert solar power for immediate use or grid export. However, without a battery, any surplus energy that is not used in the home is exported at low rates, limiting your savings. Adding storage maximises the value of your solar generation.
Key Takeaways
A solar inverter is the essential link between your solar panels and the electricity your home can actually use. Understanding how it works helps you choose the right product and get the most from your investment.
All solar inverters convert DC power from panels into AC power for home use and grid connection.
Hybrid inverters add battery management, time-of-use optimisation, and smart energy control.
Choosing an inverter with dual or multi-channel MPPT improves yield from shaded or complex roof layouts.
Sunsynk's hybrid inverter range covers residential and light commercial applications across a range of power ratings.
Whether you are planning a new solar and battery installation or upgrading an existing system, Sunsynk offers hybrid inverters built for UK conditions, UK grid standards, and UK energy tariffs.
View the full Sunsynk inverter range, including specifications, datasheets, and compatible
battery systems.
29 September 2026
22 September 2026
22 September 2026
What Is a Hybrid Inverter and How Does It Work?
22 September 2026
